Activity Forums Adobe After Effects Importing 3D in After Effects CS4
  • Importing 3D in After Effects CS4
    Posted by Khu Suh on January 14, 2009 at 7:27 pm
    I have installed After Effects CS4 on a PC and want to utilize its 3D functions. I have a Mac with Photoshop CS3 Extended.
    I imported a 3D text that I created in 3D Max in photoshop, applied an overlay effect and saved as psd.
    I imported that PSD in After Effects as a composition with Photoshop 3D Live to have it as a 3D object.
    It imports as a 3D object, but it is distorted, it is not antialised and get other artifacts which makes it useless.
    Here are the two comparisons
    Is After Effects Photoshop 3D Live not optimised yet or am I missing something. Any other with successful experiences with this workflow please enlighten me.
    Dan Smith replied 14 years, 9 months ago 5 Members · 5 Replies
  • Will Cavanagh
    January 16, 2009 at 1:04 am
    I was under the impression that AE couldn’t import 3d directly — it has to be done through Photoshop CS4 Extended.
    Now to address your question… It looks like a premultiplied/unpremultiplied issue… Although I don’t know how 3d object layers work, so I wouldn’t know how to walk you through fixing this… Can you post a screenshot of the Interpret Footage dialog for the object?
    Also, why not just do the texturing and animation in 3DS and import an image sequence… AE is not as a 3d package, and trying to use it as one is cumbersome. If you already have access to 3DS, use it!
    –Will
    getnmd.com
    nationalboston.com
  • Khu Suh
    January 16, 2009 at 3:18 pm
    Actually I did sort out that issue. It was the limitations of CS3 Extended, CS4 Extended has an option to bump up the Anti Alaising.
    However, I have noticed that using the imported 3D composition is incredibly slow. And I have not even started putting in any background animation. Just rotating an moving the object around is extremely sluggish.
    I am running a Dell 5130 Xeon 2.0Ghz with 3GD RAM on WinXP Pro.
  • Lyndon Alvarez
    August 5, 2010 at 10:51 pm
    Alright homie I got you if you havn’t already figured this out (or to anyone else who isn’t getting a response they want from these seris of posts).
    What you want to do, like already stated by (i forgot), is change the anti-aliasing.
    To do this go to window-3D.
    When the window displays, click on the top left icon. It should read “3D {SCENE}”
    Below the scene layers you will see anti-alias. It defaults to draft.
    Click on the drop down arrow and select Best.
    Now remember, when you do this and save then open up in after effects, unless you’re computers a beast it’s gonna be made slow. What I reccomend is just keep it set at draft and save. Do the work in AE till you get the animation right, save the project, open the original photoshop file & change the anti-alias to best, save, then reopen your AE file. And there you go, all your animations stick and everything looks slick.
    Hope that helps you all 😉
  • Brennan Shappell
    August 23, 2010 at 6:21 pm
    1018_pscs53dpane.jpg.zip
    This is what my 3D window looks like. For some reason, there are no aliasing options. I have tried importing a 3d studio max file and creating a 3d object in Photoshop… the window stays the same. I have also tried going to Edit->Pref.->3d enabling raytrace and open GL, to no avail. Am i missing something obvious here? It’s a little frustrating, i must admit 😉
    Thanks a lot
    Brennan
  • Dan Smith
    December 14, 2011 at 4:20 pm
    I think that Adobe changed the render engine and the AA settings no longer applied. I just applied draft raytracing (rather than the default ‘interactive’ setting) and then refreshed my model in AE. Its SLOW as anything, but it looks much better.
    d
