Activity › Forums › Adobe Premiere Pro › importing 2.0 projects into CS3
  • importing 2.0 projects into CS3
    Posted by Larry Schutte on May 21, 2008 at 1:37 am
    I just installed the Adobe CS3 Production suite and tried to import Premiere 2.0 projects into CS3. Everything imports except the timeline sequences. They are blank. I use Cineform Aspect HD. I had to upgrade to version 5 since the older version (4.5) I used with 2.0 isn’t compatable with CS3. Could this be the problem?
    Larry Schutte replied 18 years, 4 months ago 2 Members · 3 Replies
  • Jon Barrie
    May 21, 2008 at 9:27 am
    Why are you importing the projects and not opening them with CS3 then doing a SaveAs to not save over the original version made with PPro2?
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Larry Schutte
    May 21, 2008 at 3:40 pm
    Jon- I am just opening them in CS3, not importing. All the assets come in, but no timeline. It’s weird. All my projects, HD or SD in PP 2.0 will not open with the timeline in CS3.
  • Larry Schutte
    May 21, 2008 at 4:51 pm
    Jon- I solved my problem. You just double click the sequence in the project bin and the timeline appears. After a save, it opens up on startup just fine. thanks for your help. Larry
