Activity › Forums › Apple Final Cut Pro Legacy › importing 1080i 60i into 1080i 30p project
  • importing 1080i 60i into 1080i 30p project
    Posted by Dan Herz on January 9, 2009 at 6:35 am
    I am trying to import some 1080i 60i video into a project that is 1080p 30p. I have tried importing with the following settings without success:
    Sequence Preset – 1080p 30
    Capture Preset HDV
    Device Control Preset – HDV firewire (I have also tried firewire NTSC)
    Video Playback – Missing Apple Firewire NTSC (720×480) – I realize this is the wrong setting, but the only other settings options are Digital Cinema Desktop Preview or None.
    The video I am trying to import was shot on a Cannon HV20
    Any help would be appreciated
    thanks
    Dan Herz replied 17 years, 8 months ago 2 Members · 4 Replies
  • Rob Grauert
    January 9, 2009 at 1:58 pm
    I think it’s because you can’t convert interlaced footage to progressive footage on the import, or at least it’s not a good idea to.
    I would capture it with 1080 60i settings and then convert to 1080 30p in Compressor or with a Kona3 card if you have one.
    Robert J. Grauert, Jr.
  • Dan Herz
    January 9, 2009 at 2:37 pm
    I don’t have a kona card…so any other solutions you can thin of? Will FCP allow me to import at 1080 30p and then drop into timeline and render?
  • Rob Grauert
    January 9, 2009 at 3:13 pm
    Since you don’t have a Kona card I would bring your 1080 60i footage into Compressor and export it as 1080 30p. I don’t know if you can do the conversion in FCP, but even if you can, Compressor will still do a better job.
  • Dan Herz
    January 9, 2009 at 3:20 pm
    I’ll give it a shot…thanks very much for your help.
