Activity Forums Adobe Premiere Pro importing 1 single tga from a sequence
  • importing 1 single tga from a sequence
    Posted by Joep88 on May 16, 2006 at 10:23 am
    I use a lot of tga sequences and that always worked fine.
    Now i use ppro 2.0 and it looks impossible to import one single frame from a sequence. It looks like ppro2 automatically regocnizes the sequence and imports it.
    Is there a setting somewhere to prefend this ? I can not find it.
    By the way, the option Numbered Stills is OFF….
    Regards,
    Joep
    Andre Gagnon replied 20 years, 4 months ago 2 Members · 1 Reply
  • Andre Gagnon
    May 16, 2006 at 8:42 pm
    Can’t you enable the sequence, use the menu Export->Frame, set to Targa and the image under the CTI will be exported as a *.tga still?
    It certainly works for me!
