Activity Forums Adobe Encore DVD Import/export Headache
  • Import/export Headache
    Posted by Dale on July 24, 2005 at 1:12 pm
    Hi There,
    Having some probs with Encore not importing my footage. Fairly new to Encore/DVD authoring but… I have two Videos (PAL) and one, the smaller one of about 5 mins is happily accepted by Encore and transcoded on import.
    The other one, about 35 mins in length, exported from Avid Express Pro with the same settings as the 5 min video, is rejected as Encore says it is not 25fps… but it is.
    I am exporting as a QT Ref. I have gone via Soreson in the past but i just don’t get the quality for some reason. I did a Test burn with the 5 min vid and was quite happy with the quality just transcoding in Encore.
    Am I missing something?
    Thanx,
    Dale…
    Tim Kurkoski replied 21 years, 1 month ago 2 Members · 3 Replies
  • Tim Kurkoski
    July 25, 2005 at 5:18 pm
    Don’t use QT reference files. Encore has only limited capability with QT files. You’re getting an error about the frame rate because Encore is having some sort of a problem with the file, but doesn’t know exactly how to describe it, and frame rate is the closest thing it knows how to complain about.
  • Dale
    July 27, 2005 at 11:22 am
    I seem to have finally got something out of it all! I exported my QT ref file into sorenson and then it was happy…
    What do you reccomend to send to encore if not QT REF files?
    Dale…
  • Tim Kurkoski
    July 27, 2005 at 4:48 pm
    MPEG-2, ideally. AVI files are your second best route, preferably with DV or another common codec.
