Activity Forums Adobe After Effects Import/Export comp in AFX
  • Import/Export comp in AFX
    Posted by Hyperion on June 30, 2005 at 2:51 pm
    Hi everybody
    Is there any way to export a single composition from an AFX project? or maybe to import a single comp from one project to another? I always have to import the entire project and I end with huge projects.
    16:9
    Dave Tavernier replied 20 years, 11 months ago 6 Members · 8 Replies
  • 8 Replies
  • Josh Michnik
    June 30, 2005 at 3:04 pm
    well…you could just save the project as an increment and delete everything you don’t need and just leave the one comp that you need
    then import that project
  • Jeff Dobrow
    June 30, 2005 at 3:13 pm
    Simply hilight the comp in the Project window and select ‘reduce’ project from the file dropdown. This will eliminate ALL elements and comps NOT associated with the selected comp.
    Save and import into your other project. If any identical footage is used, then select ‘consolidate footage’ to eliminate redundancy.
  • Hyperion
    June 30, 2005 at 3:14 pm
    mmmmmmmmm….
    It`s not so easy…
    When I
  • Frank Ruggiero
    June 30, 2005 at 3:15 pm
    Firstly, do a ‘remove unused footage’ to get rid of everything you are not using. then, open the comp you want to keep and do a ‘reduce project.’
    remember to do a ‘save as’ immediatley afterwards so you dont save over your original project.
  • Hyperion
    June 30, 2005 at 3:22 pm
    Woooho
    Many thanks!!!
    This is amazing.
  • Aharon Rabinowitz
    June 30, 2005 at 4:16 pm
    Wow. I did not know that!
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Jeff Dobrow
    June 30, 2005 at 8:16 pm
    Drag all your ‘possible’ keeper elements you are unsure about into a comp. Then highlight both the comp you want AND the ‘storage comp’…..then proceed as above……this will allow you to keep your ‘might use’ pieces….
  • Dave Tavernier
    July 5, 2005 at 8:17 pm
    Hey Jeff,
    Off subject. Tried to contact you at VDO but Diane said you had moved on. If you don’t mind…..where can I get in touch with you? Your inside technical know how has been a great help to me in the past! Do you know anything about setting up an After Effects project for a [see Rear Screen Projector POST] PLEASE Pardon the interruption COW!
    Dave Tavernier
    WFMZ-TV
