Activity Forums Adobe Premiere Pro Importer in CS4 shuts down
  • Importer in CS4 shuts down
    Posted by Joe Bandy on November 11, 2010 at 6:42 am
    I have been having a problem importing a AVI into premiere CS4. When I import the file premiere hangs then closes down. Afterward I get an error that says the importer.exe has shut down.
    If I try to open up that project#1 again I get multiple errors and cannot import anything into the project#1. Then I receive an error that says premiere pro has encountered an error ..\..\src\remoteImporterModule.cpp-282. I’m not sure if the project#1 is now corrupt because I can open other projects but when I open project#1 Premiere gives me errors and shuts down almost as soon as I open it.
    How do I fix this problem?
    Do I just start fresh with a new project or is it my AVI?
    Steve Brame replied 15 years, 9 months ago 2 Members · 6 Replies
  • Steve Brame
    November 11, 2010 at 12:49 pm
    A bit of info is needed…
    Can you create a blank project and successfully import the AVI?
    Can you import any other AVI into project#1? There should be an auto-saved version from before the corruption.
    Did you create the AVI, or is it from another source?.
    Steve Brame
    creative illusions Productions
  • Joe Bandy
    November 11, 2010 at 8:06 pm
    No
    No
    The AVI was created from a Blu-ray disc using a ripper called AVS4you.
  • Steve Brame
    November 11, 2010 at 11:58 pm
    No
    Look like a bad AVI
    No
    “No” you can’t import any other AVI into project#1, or “No” there isn’t an auto-saved version of project#1?
    I suspect you have a bad rip.
    Steve Brame
  • Joe Bandy
    November 14, 2010 at 8:02 pm
    I’m not sure yet. I’m trying some other codecs right now.
  • Joe Bandy
    November 15, 2010 at 4:29 pm
    I have tried 15 times and still having the same issues.
    Here are the different codecs that are available.
    MPEG 4
    Microsoft MP4
    IBM Motion
    MPEG 2
    Huffman Lossless Codec
    Uncompressed Microsoft Video 1
    Intel Indeo IYUV 4:2:0
    Ceinepack Radius
    FFDS
    M102, 103, 104
    M701, 704, 705, 702
    Matrox DVC Pro
    Matrox DVC Pro 50
    Matrox MPEG2
    Which would you recommend and why?
  • Steve Brame
    November 15, 2010 at 4:40 pm
    Well, since it’s a production Blu-ray, I’d suspect that there may be a rights issue. Not sure if that carries over from a Blu-ray rip or not.
    Steve Brame
