Activity › Forums › Apple Final Cut Pro Legacy › imported titles get jagged
  • imported titles get jagged
    Posted by Kevin on June 2, 2005 at 3:44 pm
    i am importing titles as jpegs/tiffs (mostly lower 3rds) and find it necessary to sometimes resize them in fcp. this makes them
    jagged and ragged; what is the best way to do this? i generally use title 3d for this so i have no experience with this…
    thank you
    Gunner Jones replied 21 years, 4 months ago 3 Members · 2 Replies
  • Rob Forsythe
    June 2, 2005 at 4:58 pm
    This link reveals all the basics:
    https://www.kenstone.net/fcp_homepage/basic_ps.html
    VERY IMPORTANT:
    If you re-position graphics or any video image in FCP, make SURE the VERTICAL setting for each KEY-FRAME (start, stop or hold) is always a EVEN INTEGER (Even Whole Number). Examples: 4, not 3 / -144, not -143.27 / 336, not 335.62 / 12 not 11.
    The positioning settings/info (as well as many other settings) are found under the “Motion” tab in the Viewer.
    Vertical position is the number in the RIGHT window in the area called “Center” (the horizontal position is displayed in the LEFT window).
    I sometimes forget to check this and I can end up with images that look fuzzy when in-position.
    This info applies to re-positioning anything on the Timeline: moving video, freeze-frames, internally-generated titles, and imported graphics.
    It can be quite detrimental to the quality of your final output to not double-check this every time you reposition and/or re-size an image.
  • Gunner Jones
    June 2, 2005 at 9:34 pm
    Use a video monitor to check the quality.
    Get your Timeline in Safe RT mode.
    Render with the FULL bars checked in the Sequence>Render menus
    Add Rob’s advice about placement of the graphics, as well.
    …and always use a video monitor to check the quality.
    Did I mention to always use a video monitor to check quality?
    O&O-Gunner Productions
    FCP-Avid-After Effects
