Imported SWF in AfterEffects scrub through with playhead problem
With a .SWF animation imported successfully into an AE composition, when I scrub through the composition with the playhead from left to right for the first time, everything appears/plays fast normally but when I scrub through backwards (from right to left), the movie clips/graphic stack above each other and stop animating.
What seems to be the problem??
Note that I have rendered part of the composition after seeing this awkward stacking of objects in AE, and the output movie was perfectly ok.I didn’t get that with all the SWF files I have imported to AE…
