Activity Forums Apple Final Cut Pro Legacy Imported QT with Alpha issues
  • Imported QT with Alpha issues
    Posted by Todd Schmidt on March 2, 2011 at 10:48 pm
    Hello,
    I’m not a FCP user but will be very soon. However I work with clients that use FCP and we keep running into issues. I’ve been rendering out animations with After Effects in QT format, Animation Codec with alpha. I pre-multiply it. When my client imports into FCP the alpha is there but it is always “dirty” looking. Again, I don’t know FCP very well. Is there something I should be doing on my end or vice versa? I usually whip out 30 sec spots all in AE so I never have an issue.
    Todd
    Todd Schmidt replied 15 years, 6 months ago 2 Members · 3 Replies
  • Todd Schmidt
    March 2, 2011 at 11:49 pm
    Thanks for the info Dave. So I should be rendering to straight alpha for him then? I had wondered if there was a way to interpret the alpha in FCP like AE has. Then again When I import into Premiere I don’t believe there is a way either.
    Thanks for the help. I’m purchasing an older Mac and also FCP within the month. I need to learn all this.
    Todd
  • Dennis Radeke
    March 4, 2011 at 12:14 pm
    Premiere Pro understands both straight and premultiplied alpha channels: http://help.adobe.com/en_US/premierepro/cs/using/WS1c9bc5c2e465a58a91cf0b1038518aef7-7c6fa.html
    You can access the ability to ignore an alpha channel via the modify properties option of a clip.
    Hope this helps,
    Dennis
  • Todd Schmidt
    March 5, 2011 at 12:20 am
    Thank you Dennis…Appreciate it as well!
