Activity Forums Adobe After Effects Imported PSD layer duration.
  • Imported PSD layer duration.
    Posted by Tim Maddoux on January 31, 2007 at 9:28 pm
    Greetings all!
    I have imported a PSD file and would like to animate specific layers but need to change the duration of the entire comp. Each layer is only 1 frame in duration and I need to make the project 30 seconds. Any help is greatly appreciated.
    Tim
    Tim Maddoux replied 19 years, 7 months ago 2 Members · 2 Replies
  • Mike Clasby
    January 31, 2007 at 10:57 pm
    Edit Preference>Import, and check the “Length of Comp” button. Make a comp 30 sec long, now import your psd, for me if you import it as a comp, it will make the comp the same length as the last one you had, and each layer should be 30 sec long.
  • Tim Maddoux
    February 1, 2007 at 12:16 am
    Thank you yikesmikes!
    That did it!
