Activity › Forums › Boris FX › imported PSD file unable to convert to 3d container
  • imported PSD file unable to convert to 3d container
    Posted by Dewan Edwards on August 18, 2014 at 2:01 am
    Hey I imported a psd file into boris red 5. The import was successful but the convert to 3d container is grayed out. The psd is two layers, one with a layer mask for transparency, the other the background for the top layer. Basically I am trying to do a 3d photo movement. Any ideas what I may be doing wrong here/
    Boris Yamnitsky replied 12 years, 1 month ago 2 Members · 2 Replies
  • Dewan Edwards
    August 18, 2014 at 2:04 am
    never mind I got. Apparently the file was imported as video media. When I changed the video track to image the selection for 3d container was available.
  • Boris Yamnitsky
    August 19, 2014 at 6:15 pm
    Glad you were able to sort it out. Converting PS layers into separate objects is a cool feature of RED but it can not be done on movies, only on stills.
    Good luck with your project.
    Boris Yamnitsky
    BorisFX
