Activity › Forums › Adobe Encore DVD › Imported MPEG Corrupt
  • Imported MPEG Corrupt
    Posted by John Perez on January 20, 2015 at 12:00 pm
    I rendered my MPEG-2. When I play it it’s fine, but when I import it into Encore CS6 it has red image at head and tail and is terribly out of sync. What am I doing wrong?
    As always thanks so much to you guys…Johnny In Orlando
    John Perez replied 11 years, 7 months ago 3 Members · 15 Replies
  • 15 Replies
  • Jeff Pulera
    January 20, 2015 at 2:49 pm
    Hi John,
    Did you render to “MPEG-2” or “MPEG-2 DVD”? Must be the latter for Encore/DVD compatibility.
    If you can post a screen shot of the export settings used, that will be very helpful.
    Jeff Pulera
    Safe Harbor Computers
    Jeff Pulera
  • John Perez
    January 20, 2015 at 10:52 pm
    The default is “DVD” in the Custom Setting / Output File
  • John Perez
    January 20, 2015 at 10:55 pm
    FYI: Also, I rendered a short length of the timeline and it was fine when I imported it.
  • John Perez
    January 20, 2015 at 11:20 pm
    Should I render and import separately video and audio streams? Also, Encore’s default setting has lower field priority, but Vegas MPEG default is Upper field first.
  • Daniel Ludwig
    January 21, 2015 at 10:57 am
    John,
    DVD-assets should always be elementary streams, meaning audio + video in seperate files.
    acc. to field-order: forget about what encores default, the dedicated field-order you should use with your encoder is depending on the source-file. upper needs to be encoded as upper, lower as lower, otherwise you´ll generate a field-shift, which will luck jurky and like jitter.
    danny
  • John Perez
    January 21, 2015 at 11:30 am
    Thanks, Daniel,
    I will do what you suggest. In the meantime I rendered an .AVI file and imported it, and had Encore transcode (?) it. I will get back to you.
  • Jeff Pulera
    January 21, 2015 at 3:38 pm
    Been a few years since I’ve worked with Vegas, so I don’t recall the exact output settings, but there ought to be some sort of preset specifically for DVD. A Transport Stream is NOT what you want, as Daniel stated.
    It is important to have the separate video and audio clips for Encore – anything else will need to transcode (re-encode again). You should have an .m2v video clip, and audio can be .wav or .ac3 (Dolby stereo).
    Daniel is also correct about field order. NTSC DV is normally lower field first. If starting with 1080i material, then that is Upper and you can stick with UFF for the DVD, otherwise LFF is normal.
    Jeff Pulera
  • John Perez
    January 28, 2015 at 12:45 am
    Here is a list of the Vegas MPEG output options:
    Which should I use?
    FYI: I have mixed 1920 X 1080 with 1440 X 1080i on my timeline.
  • John Perez
    January 28, 2015 at 1:32 am
    Do I pick “MPEG” or “DVD” in my Output Type?
  • Jeff Pulera
    January 28, 2015 at 1:59 pm
    Sorry but there is no attachment to view
    Jeff Pulera
