Activity Forums Zaxwerks Imported logo Problem
  • Imported logo Problem
    Posted by Ted Strickler on January 30, 2009 at 5:36 pm
    I havea flat BMP logo that I want to make 3d. I imported the BMP into Photoshop CS3 and created paths then exported as an Ilustrator file. Then imported that into ProAnimator. It imported ok but part of it is filled in. What can I do about that?
    The spokes on the left part of the logo are filled in.
    Ted Strickler replied 17 years, 7 months ago 2 Members · 3 Replies
  • Ted Strickler
    January 30, 2009 at 7:36 pm
    Here is the way it imports into ProAnimator. Compression is turned off during save in AI.
  • Serge Hamad
    January 30, 2009 at 9:20 pm
    Hi again,
    Import your ai file using the “Open AS Layers” feature. This should eliminate your problem when using PS to create paths.
    Let me know if you still have problems.
    Salut.
    Serge
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Ted Strickler
    January 30, 2009 at 10:17 pm
    It imported good and looks almost perfect in edit mode but when I render a frame the inside of the wheel and some letters fill up with garbage and looks bad.
