Activity Forums Adobe Premiere Pro Imported clips gets squished?
  • Imported clips gets squished?
    Posted by Nicholas Johnson on May 5, 2011 at 10:53 pm
    So I’m importing SD footage from a GL2 – all from the same tape and same TC and actually same interview.
    I end up with a clip or two outta 10 that have horizontally squished dimensions!
    Here’s the properties of two files – as you can see the dimensions are different for some weird reason!
    CLIP 1:
    File Path: /Volumes/Viking Drobo/Documents/Premier Documents/Capture Scratch/NewRoof-Rick pt2.mov
    Type: QuickTime Movie
    File Size: 148.3 MB
    Image Size: 720 x 480
    Pixel Depth: 24
    Frame Rate: 29.97
    Source Audio Format: 48000 Hz – 16 bit – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00;00;40;23
    Average Data Rate: 3.6 MB / second
    Pixel Aspect Ratio: 0.9091
    QuickTime Details:
    Movie contains 1 video track(s), 1 audio track(s) and 1 timecode track(s).
    Video:
    This movie appears to have DROPPED FRAMES.
    There are 1221 frames with a duration of 1/29.97th.
    There is 1 frame with a duration of 1001/10000ths.
    Video track 1:
    Duration is 0;00;40;24
    Average frame rate is 29.95 fps
    Video track 1 contains 1 type(s) of video data:
    Video data block #1:
    Frame Size = 720 x 480
    Compressor = DV/DVCPRO – NTSC
    Quality = Normal (3.00)
    Temporal = Normal (3.00)
    Audio:
    Audio track 1 contains 1 type(s) of audio data:
    Audio data block #1:
    Format = 16 bit – Stereo
    Rate = 48000 Hz
    Compressor = 16-bit Little Endian
    Timecode:
    Timecode track 1 contains 1 type(s) of data:
    Timecode data block #1:
    Start Time = 00;36;37;11
    Reel name =
    CLIP 2:
    File Path: /Volumes/Viking Drobo/Documents/Premier Documents/Capture Scratch/NewRoof-Rick pt1.mov
    File Size: 244.3 MB
    Image Size: 655 x 480
    Pixel Depth: 24
    Frame Rate: 29.97
    Total Duration: 00;01;07;06
    QuickTime Details:
    Video:
    There are 2012 frames with a duration of 1/29.97th.
    Video track 1:
    Duration is 0;01;07;08
    Average frame rate is 29.96 fps
    Audio:
    Rate = 48000 Hz
    Timecode:
    Start Time = 00;35;31;22
    Reel name =
    I’m not sure why this is happening but it’s happened a few times now – it also seems to crush the blacks a bit too at the same time…
    thoughts?
    Gary Feeley replied 15 years ago 2 Members · 1 Reply
  • Gary Feeley
    August 22, 2011 at 11:10 pm
    I have been frustrated by this same problem. Capturing clips from same tape. I will check the Scene Detect Box and capture clips fine, but after looking at the clips in the project they have random sizes. They are supposed to be 720×480 but some are 873×480. I found a solution here.Interpret Footage Hope this was the answer you were after.
