Activity › Forums › Apple Final Cut Pro › Imported clip get cut off?
  • Imported clip get cut off?
    Posted by Erick Puentes on November 2, 2018 at 6:43 pm
    I have a clip I imported and the last few seconds get cut off. I’m not sure what is going on. I tried reimporting but I get the same result. It will play just fine in QT so I’m not sure what the issue can be. Does anybody encounter this problem?
    Specs of the file in question:
    Eric Santiago replied 7 years, 11 months ago 2 Members · 1 Reply
  • Eric Santiago
    November 3, 2018 at 3:31 pm
    Can you use another app to convert to ProRes then import?
    MPEG StreamClip or even VLC will do.
    Assuming you dont have Compressor or AME.
