Activity Forums Adobe Premiere Pro Imported Avid footage shows red frames and audio?
  • Imported Avid footage shows red frames and audio?
    Posted by Bob Miller on October 17, 2014 at 2:09 am
    Hello,
    So, my editor gave me avid footage exported as “same as source” aka VC-3 (DNxHD) footage and when I try to transcode it into another format in Adobe Media Encoder (latest verson CC) it starts out with some picture then goes to a RED image with the sound underneath it.
    Adobe Premiere (latest version CC) does the same thing if I try to edit the footage natively.
    And yet free apps like Handbrake seem to transcode the footage okay.
    I have Avid on my computer and installed all of the codecs, so I’m baffled as to what’s going on.
    Any help would be appreciated! Specific data on the file below images.
    File Data I’m trying to use:
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 28.7 GiB
    Duration : 1h 30mn
    Overall bit rate : 45.2 Mbps
    Encoded date : UTC 2014-10-17 00:05:05
    Tagged date : UTC 2014-10-17 00:19:05
    Writing library : Apple QuickTime
    Video
    Format : VC-3
    Codec ID : AVdn
    Codec ID/Info : Avid
    Codec ID/Hint : DNxHD
    Duration : 1h 30mn
    Bit rate mode : Constant
    Bit rate : 43.7 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.878
    Stream size : 27.7 GiB (97%)
    Bob Miller replied 11 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
