Activity Forums Adobe Premiere Pro Imported After Effects compositions shifted to the left in Premiere Pro 2023
  • Imported After Effects compositions shifted to the left in Premiere Pro 2023
    Posted by Frank Baumann on November 14, 2023 at 6:30 pm
    I recently installed AE and PP 2023 after using CC 2015 for a long time, and now my imported AE compositions are shifted slightly to the left in Premiere Pro 2023 (attached screenshots). I am using Windows 11.
    The versions of AE and PP match, and no errors when importing or rendering. When I render the composition in AE 2023, it looks fine, so it’s probably a Dynamic Link issue or Premiere Pro 2023 issue or something else that I overlook.
    Does anyone have any suggestions how to fix this? Or how could I try to re-install Dynamic Link or reset the preferences? Or anything else? Many thanks!
    Ann Bens replied 2 years, 9 months ago 3 Members · 4 Replies
  • Eric Santiago
    November 15, 2023 at 3:21 am
    Not sure you can install Dynamic Link on its own.
    I would do a complete clean install.
    Remove all Adobe products and start over.
    How about CC 2024?
  • Frank Baumann
    November 15, 2023 at 8:52 am
    Thank you, this is my next step, uninstalling everything and re-installing.
    This is what it looks like in the GUI. In the program monitor, a part from the left side is cut off and inserted on the right, shifting the composition to the left.
    Strangely, this only occurs with After Effects compositions. Otherwise, Premiere works normally. So it is probably not a graphics driver issue, or not even a Dynamic Link isse, more a problem in the interpretation of imported compositions.
  • Frank Baumann
    November 15, 2023 at 9:18 am
    I found a solution: Update everything to 23.6. It seems there was some incompatibility before, as described here.
    https://community.adobe.com/t5/premiere-pro-discussions/dynamic-link-picture-cut/td-p/14003891
  • Ann Bens
    November 19, 2023 at 1:02 pm
    Know issue: all apps need to be of the same version.
    https://helpx.adobe.com/premiere-pro/kb/known-issues.html
    June 2023 Release (Version 23.5)
