Activity Forums Avid Media Composer IMPORTED AAF IS DROP FRAME WHEN ORIGINAL PROJECT WAS NON DROP
  • IMPORTED AAF IS DROP FRAME WHEN ORIGINAL PROJECT WAS NON DROP
    Posted by Stephen Brooks on January 5, 2007 at 4:30 am
    Non drop project in Adobe Premiere Pro 2.0. Exported via AAF. When imported into Xpress Pro 5.6.4 it becomes drop frame. I have all the settings set to Non Drop. Premiere is XP, Avid is Mac.
    Thanks for any insights.
    Stephen Brooks replied 19 years, 8 months ago 2 Members · 5 Replies
  • John Pale
    January 5, 2007 at 5:32 pm
    Is this a sequence? You could change it back very easily…or did all the source timecode change to DF?
  • Stephen Brooks
    January 5, 2007 at 5:41 pm
    Yes it is a sequence. All the clips are DF as well. When I try to change the sequence to NDF (right clicking, modify) I get an error message saying I cannot do that. When I try to modify the clips Avid crashes. It just disappears. No error messages.
    Thanks for your insights. I’m still not sure this isn’t a Premiere export problem. But I have no way to test that.
  • Stephen Brooks
    January 6, 2007 at 10:59 pm
    I just re-imported the AAF into a new Premiere project and it comes in as NDF. So it must be an Avid issue. Any other ideas?
    Thanks.
    Stephen
  • John Pale
    January 7, 2007 at 2:35 am
    just for laughs, check to make sure your preference for new sequence creation is set for DF. The default setting is NDF.
  • Stephen Brooks
    January 9, 2007 at 6:17 pm
    Turns out this is a bug. Avid has my aaf to test. At least I’m not crazy!
    Thanks for all the suggestions.
