Activity Forums Adobe Illustrator important question about a design
  • important question about a design
    Posted by Chaim Machlev on January 30, 2014 at 12:36 am
    sorry to disturb you guys but i am trying for weeks to find a way to create a design like this one,
    does anyone has a clue which tools i should use ?
    Thanks a lot
    I really appreciate it !
    Vincent Rosati replied 12 years, 7 months ago 2 Members · 1 Reply
  • Vincent Rosati
    January 30, 2014 at 9:29 pm
    Oh brother! You’re getting into more advanced type illustration, given this example.
    Here are the steps outlined in the attached AI file.
    I’m sure there are a dozen ways you could do this, but hopefully this will give you some ideas.
    1 – Create an object with the Polygon tool.
    2 – Make it fancy.
    Object Blend Specified Steps.
    Add Effect Distort Zig Zag.
    Expand.
    Pathfinder Minus Back.
    Cleanup.
    3 – Duplicate with Cmd + D to create the pattern.
    See: https://library.creativecow.net/articles/rosati_vincent/radial_patterns.php
    4 – Object Envelope Distort Make with Top Object.
    Working example file here:
    7074_warpedpatternv10.ai.zip
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
