Activity › Forums › Compression Techniques › Important Compression Question
Posted by Dan Newton on April 11, 2009 at 6:17 pmI have three questions —
i have the following programs —-
SQUEEZE and COMPRESSOR
I want to do the following
how do you convert a MOV to FLV
how do you convert a MOV MPEG 2
how do you convert a MOV to AVI
Could someone please write out a step by step on how to do each one its extremely important
Daniel Low replied 17 years, 5 months ago 2 Members · 9 Replies -
Daniel Low
April 11, 2009 at 7:51 pmUse the supplied presets in either program and applied them to your imported MOVs, it couldn’t be simpler!
Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004 -
Daniel Low
April 12, 2009 at 10:07 amWhat kind of AVI to you want to create?
Dan Newton
April 12, 2009 at 10:27 amwell the MOV is
720 x 576
25 frames
so i want to make the AVI similar
Daniel Low
April 12, 2009 at 10:33 amYes but AVI is a format, not a codec, what AVI codec do you need to export to?
Dan Newton
April 12, 2009 at 10:40 amHey
Sorry I’m new to this conversion thing to avi — can you explain the type of codecs they have —
which one do you recommend
Daniel Low
April 12, 2009 at 10:44 amWhat are the AVIs going to be used for?
Dan Newton
April 12, 2009 at 11:00 amwell one of three things
for personal viewing like a high res mpeg
Daniel Low
April 12, 2009 at 1:01 pmI try and avoid AVI unless it’s DV AVI.
Have a go with this:
https://www.divx.com/en/products/software/mac/divx
It’s the most popular AVI codec.
