Activity Forums Adobe After Effects Important Advice Needed compositing a video
  • Important Advice Needed compositing a video
    Posted by Chris Lingard on May 11, 2011 at 12:01 am
    Hi my names Chris,
    I am currently at Teesside Uni and I am trying to render out my final year project but I am having problems.
    I rendered all my frames from Softimage using the HD 1280×720 res however when I try compressing all the image files in After Effects it speeds up my work making the whole scene not synced with my audio track anymore. In after effets i have been trying to render through Quick Time movie player running at 25 frames a second.
    Any one got any suggestions on how this can be sorted? I am really struggling 🙁
    Chris Lingard replied 15 years, 4 months ago 3 Members · 3 Replies
  • Brian Charles
    May 11, 2011 at 12:52 am
    Sounds likely that After Effects is not interpreting the SoftImage footage correctly. Right-click on the footage in the Project pane and select Interpret Footage > Main. Then set the correct frame rate for the footage.
    https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103906c6dea-7f82a.html
  • Walter Soyka
    May 11, 2011 at 1:33 am
    One addition to Brian’s solution: the default frame rate for imported image sequences is 30 fps. You can change this default under Preferences > Import > Sequence Footage.
    Walter Soyka
  • Chris Lingard
    May 11, 2011 at 2:07 am
    Thanks guys 🙂
