Activity Forums Adobe Premiere Pro Import Window ocasionally looses Option Import Sequential Images
  • Import Window ocasionally looses Option Import Sequential Images
    Posted by Jeff Burford on January 9, 2006 at 11:32 am
    Also have the problem that the Import Widow looses the option of importing sequential images. (there is no option to set).
    Regards,
    Jeff
    Noctral replied 20 years, 5 months ago 3 Members · 3 Replies
  • Robertp
    January 9, 2006 at 6:14 pm
    If there is an image missing in the sequence it won’t show up
  • Jeff Burford
    January 11, 2006 at 9:57 am
    Thanks for the reply. However, I just found out from the colleagues that
    when this happens, they can go to another Premiere Workstation and import the sequence without problem. (the option shows up there).
    Any other ideas?
  • Noctral
    April 3, 2006 at 12:37 pm
    Hello Jeff,
    I’ve read this thread while ago and i was dealing with the same problem till today. Nearly 3 months past till your post but haven’t seen an answer. After my last config setup i haven’t come across this import sequence problem. But today i lost numbered stills option again and the only difference was my left side of the premiere window bar wasn’t completely snaped to the monitor viewing area. I snapped it and tried importing again and whoa numbered stills option was back. So i didn’t believe that this could be the source of the problem. After playing with the window bars for 15 minutes i accept it. Call it an easter egg or a bug. Hope this will come handy for whom loses their numbered still options.
