Activity Forums Adobe Premiere Pro Import Video Only (No Audio) Into Adobe Premiere CS4
  • Import Video Only (No Audio) Into Adobe Premiere CS4
    Posted by Aldo Turner on February 8, 2010 at 10:35 am
    Does anybody know how/if I can import only the video(without the audio) of a video file into Adobe Premiere CS4?
    I have many .mpg files that I only use only the video from and the way Premiere works, it is very frustrating that it takes such a long time to ‘conform’ the audio and also the amount of hard disk space it uses.
    I have tried creating an offline video only clip and linking it, but that crashes Premiere and I know I could convert the clips to video only before importing, but I wondered if Premiere can import just video.
    I suppose it’s not a major issue but any help would be greatly received.
    Brian Louis replied 16 years, 7 months ago 2 Members · 1 Reply
  • Brian Louis
    February 8, 2010 at 1:33 pm
    Unless you have Elemental Streams Mpg files are usually muxed so you would have to either demux the files in premiere or another software before being able to seperate the A/V
