Activity Forums Adobe After Effects Expressions Import video into comps script
  • Import video into comps script
    Posted by Matt Volp on September 11, 2017 at 12:06 pm
    Hi all,
    Let’s say we have three comps in the project panel, named “Lorem”, “Ipsum” and “Dolor”.
    Let’s also say we have three video files (.movs) imported into the project panel named “Lorem”, “Ipsum” and “Dolor”.
    I want to run a script which will add the video file named “Lorem” to the comp named “Lorem”, the the video file named “Ipsum” to the comp named “Ipsum” and the video file named “Dolor” to the comp named “Dolor”.
    It’s important to note that the comps will already have been made, they are just lacking the relevant video files.
    There could be three files like in this example or there could be hundreds.
    So far I have this:
    var myProject = app.project;
    for (var i = 1; i <= myProject.numItems; i++){ if (myProject.item(i) instanceof CompItem){ var myComp = myProject.item(i); } if (myProject.item(i) instanceof FootageItem){ var myFootage = myProject.item(i); } if (myComp.name == myFootage.name){ myComp.layers.add(myFootage); } } It works, but is it what you guys would do?
    Matt Volp replied 8 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 11, 2017 at 1:26 pm
    Something like this maybe:
    function findComp(theName){
    for (var i = 1; i <= app.project.numItems; i++){
    if ((app.project.item(i) instanceof CompItem) && (app.project.item(i).name == theName)){
    return app.project.item(i);
    return null;
    var myItem;
    var myComp;
    myItem = app.project.item(i);
    if ((myItem instanceof FootageItem) && (myItem.name.toLowerCase().substr(-4) == ".mov")){
    myComp = findComp(myItem.name.substr(0,myItem.name.length-4));
    if (! (myComp == null)){
    myComp.layers.add(myItem);
    Dan
  • Matt Volp
    September 11, 2017 at 1:47 pm
    I thought it would include a function.
    I’ve learned a lot there, Dan.
