Activity Forums Apple Final Cut Pro Legacy import video files from Vegas 6
  • import video files from Vegas 6
    Posted by Will Moffitt on October 26, 2006 at 6:39 pm
    I have a project where I need to import edited video files from a PC using Vegas 6 into my FCP system. The question is what files format should the files be rendered to in Vegas to give me the best quality in FCP?
    Izoneguy replied 19 years, 11 months ago 3 Members · 4 Replies
  • Chris Poisson
    October 26, 2006 at 7:42 pm
    What format are they in in Vegas? What format are you working in FCP? If DV, then export as DV Quicktime. If uncompressed AVI then output as 8 or 10 bit uncompressed.
  • Will Moffitt
    October 26, 2006 at 8:17 pm
    The files are NTSC DV on the Vegas system and will go into a DV sequence on the Final Cut system. Will the Vegas render files as Quicktime DV?
    Will
  • Chris Poisson
    October 26, 2006 at 10:16 pm
    Don’t see why not.
  • Izoneguy
    October 26, 2006 at 11:39 pm
    Or you can just load the DV files into the MAC
    and use QT to convert…
    Just did this for a show…
    We converted the DV to DVCPRO 50 as we
    had interviews and some B-roll in DVCPRO 50…
    Everything looked so much better than editing in DV….
