Activity Forums VEGAS Pro import Vegas edl into FCP – ?
  • import Vegas edl into FCP – ?
    Posted by Angela Anderson on June 13, 2008 at 10:15 am
    I realize there was a post where somebody supposedly did this successfully by going from vegas to excel to fcp – unfortunately, there were no details mentioned, which, of course, are what one needs to know to do something like this.
    I exported a test .edl from vegas, and tried importing it into fcp. when i click on the .edl, fcp crashes. just disappears into the abyss of my macbook. um, hello? i have two problems – the first is the edl itself.
    here is what i got from vegas:
    TITLE: a futur_Didier_mac test
    FCM: NON-DROP FRAME
    001 UNKNOWN V C 00:10:32,17 00:11:24,23 00:00:00,00 00:00:52,06
    * FROM CLIP NAME: t16 – interview didier
    002 UNKNOWN V C 00:11:27,00 00:12:10,14 00:00:52,06 00:01:35,20
    003 UNKNOWN AA C 00:10:32,17 00:11:25,14 00:00:00,00 00:00:52,22
    004 UNKNOWN AA C 00:11:25,14 00:11:25,14 00:00:52,22 00:00:52,22
    004 UNKNOWN AA D 013 00:00:04,19 00:00:09,16 00:00:53,10 00:00:58,07
    * TO CLIP NAME: t22 – susanne texte 002 – 000
    005 UNKNOWN AA C 00:00:09,16 00:00:09,16 00:00:58,07 00:00:58,07
    005 UNKNOWN AA D 002 00:11:34,10 00:12:02,11 00:00:59,16 00:01:27,17
    * FROM CLIP NAME: t22 – susanne texte 002 – 000
    * TO CLIP NAME: t16 – interview didier
    006 UNKNOWN AA C 00:12:02,11 00:12:02,11 00:01:27,17 00:01:27,17
    006 UNKNOWN AA D 014 00:12:04,12 00:12:10,14 00:01:29,18 00:01:35,20
    007 UNKNOWN AA C 00:12:11,00 00:12:11,00 00:01:35,08 00:01:35,08
    I have no idea if this works with FCP or if not, what i have to do to it to make it recognizable.
    second, in FCP, in order to import an edl, i choose the “reconnect” option and i have to choose a setting – i’m assuming i choose the HDV 720p 25 since the footage was shot on a JVC hdv 110, since that’s what i would choose if i was capturing media from the camera.
    Any ideas how i get this to work?
    and yes, the project was pretty much all edited in vegas – the problem is the director works with fcp and wants to now take over editing the project and basically have control over it from the current editor. thus all the hassle.
    Elvir Surkovic replied 15 years, 11 months ago 4 Members · 10 Replies
  • 10 Replies
  • John Rofrano
    June 13, 2008 at 1:50 pm
    Unfortunately, I don’t have an answer for you and a quick Google search turned up lots of posts about FCP blowing up on EDL import with no resolution, but before you drive yourself crazy getting this to work, I thought I would point a few things out. The EDL Export in Vegas only supports the first Video track and Audio track. So if your Vegas project has more than one video and audio track this isn’t going give you what you expect. Also it only supports cuts and cross fades (dissolves). No FX or transitions of any kind will be exported so any color correcting or other processing will be lost.
    I just wanted to be sure you knew this so that you don’t spend a lot of time getting it to work only to find that is not what you expected. Good luck.
    ~jr
    https://www.johnrofrano.com/
  • Elvir Surkovic
    July 4, 2008 at 11:52 am
    I had to solve the same problem for my company. The problem is in the EDL file generated by Vegas, which does not fit FCP EDL file expected.
    So I developed vb script to correct the EDL file generated by Vegas to fit expected FCP EDL format.
    First, export edl as you did, then start this script to make necessary corrections (Tools->Scripting->Run Script).
    Save this script text to text file, which must have an .vb extension:
    ———————————————Script Start———————————————-
    Imports System.Windows.Forms
    Imports System
    Imports Sony.Vegas
    Imports System.IO
    Imports System.Array
    Public Module MainModule
    Sub Main
            Const fileTag As String = "_BHRT.EDL"           'Change original EDL filename to indicate sucessfull script operation
            Dim openFileDialog1 As New OpenFileDialog()
            Dim inFile As String
            Dim outFile As String
            openFileDialog1.InitialDirectory = "c:\"
            openFileDialog1.Filter = "edl files (*.edl)|*.edl"
            openFileDialog1.FilterIndex = 2
            openFileDialog1.RestoreDirectory = True
            'MessageBox.Show("hello world")
            'openFileDialog1.ShowDialog()
            If openFileDialog1.ShowDialog() = DialogResult.OK Then
                inFile = openFileDialog1.FileName
                If Not (inFile Is Nothing) Then
                    ' Insert code to read the stream here.
                    outFile = inFile.Remove(inFile.Length - 4) + fileTag
                    Dim files As FileClass = New FileClass(inFile, outFile, "")
                    files.pullLines()
                    files.pullClips()
                    files.closeFiles()
                    My.Computer.FileSystem.DeleteFile(inFile)
                End If
            Else
                Application.Exit()
            End If
    End Sub
    Public Class FileClass
            Const EDL_Identifier As String = "* FROM CLIP NAME:"    'Do not change this constant
            Const EDL_IdentifierCorrection As String = "  "         'Do not change this constant
            Const EDL_FilesExtension As String = ".MOV"             'Change this constant to your video files extension (.avi,...)
            Const EDL_ReelOld As String = "UNKNOWN"                 'Do not change this constant
            Const EDL_ReelPrefix As String = "FC"                   'Prefix to reel names in EDL list (You can change this constant as you wish)
            Private f1Stream As FileStream      ' file: originalni EDL
            Private f1Reader As StreamReader    '
            Private f1Name As String
            Private f2Stream As FileStream      ' file: novi EDL
            Private f2Reader As StreamWriter    '
            Private f2Name As String
            Private f3Stream As FileStream      ' file: log
            Private f3Reader As StreamWriter    '
            Private f3Name As String
            Private linesListArr As String()
            Private linesList_TagArr As String()
            Private linesIndex As Integer = 0
            Private linesEnd As Boolean = False
            Private clipsTmpArr As String()
            Private clipsListArr As String()
            Private linesEDLArr As String()
            Public Sub New(ByVal p1FileName As String, ByVal p2FileName As String, ByVal p3FileName As String)
                f1Name = p1FileName
                f2Name = p2FileName
                f3Name = p3FileName
                Try
                    If (p1FileName IsNot Nothing) And (p1FileName <> "") Then
                        f1Stream = New FileStream(f1Name, FileMode.Open, FileAccess.Read)
                        f1Reader = New StreamReader(f1Stream)
                    End If
                    If (p2FileName IsNot Nothing) And (p2FileName <> "") Then
                        f2Stream = New FileStream(f2Name, FileMode.OpenOrCreate, FileAccess.Write)
                        f2Reader = New StreamWriter(f2Stream)
                    End If
                    If (p3FileName IsNot Nothing) And (p3FileName <> "") Then
                        f3Stream = New FileStream(f3Name, FileMode.OpenOrCreate, FileAccess.Write)
                        f3Reader = New StreamWriter(f3Stream)
                    End If
                Catch ex As Exception
                    MsgBox("File does not exist", MsgBoxStyle.Critical, "Sony Vegas Script")
                End Try
            End Sub
            Public Sub closeFiles()
                f1Reader.Close()
                f1Stream.Close()
                f2Reader.Close()
                f2Stream.Close()
                'f3Reader.Close()
                'f3Stream.Close()
            End Sub
            Public Sub pullLines()
                Dim index As Integer = 0
                ReDim Preserve linesListArr(2000)
                Do Until f1Reader.EndOfStream
                    linesListArr(index) = f1Reader.ReadLine()
                    index = index + 1
                Loop
                ReDim Preserve linesListArr(index - 1)
                ReDim Preserve linesList_TagArr(index - 1)
                ReDim Preserve linesEDLArr(index - 1)
            End Sub
            Public Sub pullClips()
                Dim i As Integer
                Dim j As Integer = 0
                Dim sPom As String = ""
                ReDim Preserve clipsListArr(0)
                ReDim clipsTmpArr(linesListArr.Length - 1)
                For i = 0 To linesListArr.Length - 1
                    If linesListArr(i).Length > 17 Then
                        sPom = linesListArr(i).Substring(0, 17)
                    End If
                    linesList_TagArr(i) = ""
                    If sPom = EDL_Identifier Then
                        clipsTmpArr(j) = linesListArr(i).Substring(18, linesListArr(i).Length - 18)
                        linesList_TagArr(i) = clipsTmpArr(j)
                        j = j + 1
                    End If
                Next
                ReDim Preserve clipsTmpArr(j - 1)
                Array.Sort(clipsTmpArr)
                ReDim Preserve clipsListArr(j - 1)
                j = 0
                clipsListArr(0) = clipsTmpArr(0)
                For i = 0 To clipsTmpArr.Length - 1
                    If clipsListArr(j) <> clipsTmpArr(i) Then
                        j = j + 1
                        clipsListArr(j) = clipsTmpArr(i)
                    End If
                Next
                ReDim Preserve clipsListArr(j)
                createLines_EDL()
                For i = 0 To linesEDLArr.Length - 1
                    insLine_EDL(linesEDLArr(i))
                Next
            End Sub
            Public Sub createLines_EDL()
                Dim i As Integer
                linesEDLArr(0) = linesListArr(0)
                linesEDLArr(1) = linesListArr(1)
                For i = 2 To linesListArr.Length - 2 Step 2
                    linesEDLArr(i) = linesListArr(i)
                    linesEDLArr(i) = linesListArr(i).Replace(EDL_ReelOld, EDL_ReelPrefix + findReel(i + 1))
                Next
                For i = 3 To linesListArr.Length - 1 Step 2
                    linesEDLArr(i) = EDL_Identifier + EDL_IdentifierCorrection + linesList_TagArr(i) + EDL_FilesExtension
                Next
            End Sub
            Private Function findReel(ByVal index As Integer) As String
                Dim i As Integer
                For i = 0 To clipsListArr.Length - 1
                    If linesList_TagArr(index) = clipsListArr(i) Then
                        Return (i + 1).ToString
                    End If
                Next
                Return ""
            End Function
            Public Sub insLine_EDL(ByVal line As String)
                Dim txtLine As String
                txtLine = line
                f2Reader.WriteLine(txtLine)
            End Sub
            Public Sub insLine_comment(ByVal comment As String)
                txtLine = comment
                f3Reader.WriteLine(txtLine)
            End Sub
            Public Sub resetIndex()
                linesIndex = 0
            End Sub
            Public ReadOnly Property ProductsList() As String()
                Get
                    Return linesListArr
                End Get
            End Property
            Public ReadOnly Property ProductsListIndex() As Integer
                Get
                    Return linesIndex
                End Get
            End Property
            Public ReadOnly Property ProductsListEnd() As Boolean
                Get
                    Return linesEnd
                End Get
            End Property
    End Class
    End Module
    ———————————————Script End————————————————
  • Angela Anderson
    August 5, 2008 at 11:28 am
    hi elvir,
    i’m wondering if you can walk me through how exactly to use this script in very basic language – i’ve tried to use it recently in vegas, what i did was: export the edl –> then tools-scripting-run script (like you said)
    then i got a window that asked me to locate the script, which was saved as .vb (not .vb.txt) but when i would navigate to the file location, it did not show up. it simply wasn’t there. any ideas?
    i don’t use a pc, and i have no idea about scripting language. there seem to be places in the script where i’m supposed to change the variables, but that’s just a guess and i don’t really know what to/how to do it.
    any advice is very welcome!
  • Elvir Surkovic
    August 11, 2008 at 9:05 am
    hi angela,
    You should really have no problems with finding the file through Vegas window.
    One of the reasons could be that(in Windows Explorer) Tools->Folder Options->View->Hide Extensions for known files is checked. If it is the case, you cannot see the default extension of txt file.
    Go to (Using Windows Explorer):C:\Program Files\Sony\Vegas Pro 8.0\Script Menu. In that folder you should see some script files with extension .js and .cs. If you cannot see that extension, it means that you have to make that option unchecked.
    Also, try to put the file you created in this folder, you should see it in the Tools->Scripting menu. If Vegas is already open, Run Tools->Scripting->Rescan Script Menu Folder, to make it know about your file.
    I hope this will help you.
  • Andi Nakasone
    September 14, 2010 at 9:55 am
    Hi Elvir, I have the same problem trying to get my Vegas files succesfully converted to work with FCP. I’m not sure if you’ll get this message or not anymore but I’m trying to get your script to work with Vegas 9.0 but I keep getting this error when I try to run it, it says:
    An error occured during execution of the script
    System.NotSupportedException: Language not supported.
    at Sony.Vegas.ScriptHost.RunScript(Boolean fCompileOnly)
    Is there way to fix this by chance?
  • Elvir Surkovic
    September 21, 2010 at 11:29 am
    Hi Andi,
    I did not test the code with Vegas ver 9.0, but it should work as well as with older version. I will test the code and let you know about the results.
  • Andi Nakasone
    September 22, 2010 at 5:55 am
    Hi and thanks a lot for replying! Let me know if it works, I’ve never used scripts with vegas before, its possible I might have used it wrong as this is all new to me. But if you can help me with some basic instructions on how to use the script, I will greatly appreciate it!
    -Andi
  • Andi Nakasone
    September 23, 2010 at 10:18 pm
    Hi Elvir, I hope I’m not bothering you to much with this but by chance has there been any luck with the script so far? Is it possible you can email me the script file and instructions on how to use it to my email at: andi.nakasone@gmail.com
    I would greatly appreciate your help with getting my vegas project to work as a FCP project this weekend, so much so that I would be more than happy to pay you a little something for your time, thanks again!
    -Andi
  • Andi Nakasone
    September 29, 2010 at 12:02 am
    By any chance has there been any confirmation of success yet? I’m really sorry about troubling you over this, but this information is quite time sensitive to know, and like I said I can reimburse you for any time you spend on the issue if you like.
    -Andi
  • Elvir Surkovic
    September 29, 2010 at 6:54 am
    I have sent email to andi.nakasone@gmail.com with attached tool. Please, check your inbox.
    You can reach me at: e.surkovic@ieee.org
