Activity Forums Square Box CatDV Import using CatDV XML Batch File failures / Worker 5.0.6
  • Import using CatDV XML Batch File failures / Worker 5.0.6
    Posted by Leonid Nekrasov on October 7, 2013 at 11:24 am
    Hello everybody,
    since Update from Worker 4 to 5 I cannot use CatDV XML Batchfile Import. The files will be imported, but I miss all Metadata provided in the XML File. Besides the Worker Update, nothing was changed on the system or on the XML Format.
    I tried both ways to import the immediate and the classic mode, but nothing works.
    Has anybody observed similar effects? Any Idea what I can do?
    I use CatDV Server 6.0.7. on Mac OS Server 10.6.8
    Thx and regards
    Leo
    LinkedIn: https://goo.gl/CPSnl
    Leonid Nekrasov replied 12 years, 10 months ago 2 Members · 2 Replies
  • Bryson Jones
    October 8, 2013 at 6:59 pm
    Are you getting the java.lang.NullPointerException?
    I’m seeing that on a test I’m running. I’ll post up results.
    bryson
    bryson “at” northshoreautomation.com
  • Leonid Nekrasov
    October 10, 2013 at 6:54 am
    Hi Bryson,
    I have to study the Log file first. Meanwhile I did several tests. This is what I have observed:
    TEST 1
    – export an existing clip as an FCP 7 XML file
    – drop it in the watch folder for Worker
    – Configure Workerjob : File Job, Interpret Batch FIles: true
    – Result: the file is being imported. The Filed “Notes” was parsed in a wright way. All other fields are USER fields and the were remained empty.
    TEST 2
    – export an existing clip as an FCP Batch File
    – Result: the file is being imported as a text file. no Video was recognized. No metadata imported.
    TEST 3
    – make manually a CatDV XML Batch File with a text editor and give it the same name as the video clip
    – drop the viodeoclip and the XML file in the watch folder for Worker
    – Result: the file is being imported. All Metadata were parsed in a wright way. All Metadata war there.
    – Success
    TEST 4
    – same CatDV XML Batch File as in Test 3. Videoclip stored in another directory. The Path is mentioned in the XML under MEDIAPATH
    – drop the XML file in the watch folder for Worker
    – Configure Workerjob : Batch Job, Interpret Batch FIles: true
    – Result: the file is being imported as a video file. No metadata imported
    Worker can recognize the Metadata only if I process a File Job and use the CatDV XML File as a sidecar file. Both must be in the same directory and have the same names. Good to know, it works this way, but not good for my workflow.
    I contacted the support of Squarebox and I hope to get a solution as soon as possible since I purchased another Worker Instance a couple of days ago.
    Regards
    Leo
