Activity Forums VEGAS Pro Import un numbered chapter markers
  • Import un numbered chapter markers
    Posted by Paul Gregory on July 24, 2006 at 11:02 pm
    Here is a very small question about when you import chapter markers into DVDA. When you create them in Vegas they seem to get numbered in the order that they are created. When I use these markers for creating a scene selection menu I never use the numbers – only the name. This means that I have to edit the name of every marker to remove the number. Did I miss an option for importing only the name without the number?
    Thanks in advance
    Peter Wright replied 20 years, 1 month ago 2 Members · 1 Reply
  • Peter Wright
    July 25, 2006 at 12:50 am
    No, the chapters always initially have with numbers – on some projects this can be useful, but like you I generally go through and rename them without the number.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
