Activity › Forums › Adobe Premiere Pro › Import Trouble Remains, Deadline Coming
  • Import Trouble Remains, Deadline Coming
    Posted by Than Baardson on June 23, 2009 at 2:35 pm
    I’m importing an .avi that I rendered out of AE. It rendered lossless and the file looks good in an outside player.
    When I bring the file into Premiere, it gets very pixley and looks compressed. Premiere is set to ‘Highest Quality’ and I and a few others on the AE forum are stumped. I’ve tried pulling the comp directly from AE and there’s no change. Any suggestions?
    Tim Kolb replied 17 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Vince Becquiot
    June 23, 2009 at 3:15 pm
    Is this psrt of a previous post, so that we don’t go through the same questions?
    Could you post details about your settings?
    First, check that it is interpreted correctly in the project panel.
    What PAR is your comp in AE ?
    What does the export from Premiere look like?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Than Baardson
    June 23, 2009 at 6:42 pm
    720 x 480
    PAR: D1/Dv ntsc (0.9)
    29.97 fps
    Rendering Plug-in: Advanced 3D
    Here’s what it looks like in AE-
    Here it is when it gets to Premiere-
  • Vince Becquiot
    June 23, 2009 at 6:54 pm
    First, your program panel in Premiere is set to 150%, and the one in AE to 200% so it’s hard to judge since that always create pixelation.
    I don’t know the settings you are using in AE, but try setting the interpret setting PAR to 1.0 for this clip in Premiere, since that’s what it should be if you are working with a default AE setting.
    Vince Becquiot
    Kaptis Studios
  • Than Baardson
    June 23, 2009 at 7:03 pm
    Oh sorry about that, it’s a little tough to tell by the pictures. Once it goes to big screen, it looks like junk.
    How do I change the PAR in Premiere?
  • Vince Becquiot
    June 23, 2009 at 7:20 pm
    Right click on the clip, and select interpret footage.
    Vince Becquiot
    Kaptis Studios
  • Than Baardson
    June 23, 2009 at 7:28 pm
    Vince! I think that did it sir. Thanks so much for the help!
    -Than
  • Than Baardson
    June 25, 2009 at 3:26 pm
    Thought it worked but now it’s gone back to looking like crud. I’m completely stumped now.
    I tried re-doing the project in an hd format, thinking maybe that would help, but have seen the same results.
    Frustrating…
  • Tim Kolb
    June 28, 2009 at 3:14 am
    depending on what you do to change the format you’re editing in…the pixel aspect interpretation will need to be different.
    TimK,
    Director, Consultant
    Kolb Productions,
