Activity Forums Apple Final Cut Pro Legacy import tif files as sequence???
  • import tif files as sequence???
    Posted by Juliett on February 27, 2006 at 12:22 pm
    Hi Everyone
    I have just received some tif files (lots of them) on a LacieDrive to import into my final cut project as a sequence. The footage was shot on a high speed camera which directly stored onto te drive.
    Does anybody know how I can import these files as a sequence.
    Any help would be appreciated.
    Julie 🙂
    Juliett replied 20 years, 7 months ago 2 Members · 2 Replies
  • Tom Wolsky
    February 27, 2006 at 12:37 pm
    If they’re numbered sequentially (hopefully) you can set the FCP stills import preference to one frame and import the folder. There will be a 999 frame limit before the file sequence gets wonky. You could also use the QuickTime Pro player. Use Open>Image Sequence. Select the first numbered image in the sequence and open it. Set the frame rate. Then export to a QT file in the format your’re working in.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Juliett
    February 27, 2006 at 4:56 pm
    Hi Tom
    Thank you for the reply
    I chose to do it via Quick Time and it worked. However when I insert this QT clip into my timeline the red bar appears asking for it to be rendered. Is this normal?
    Julie
