Activity Forums Adobe Premiere Pro Import Sony camera clips into Premiere Pro CC 2015
  • Import Sony camera clips into Premiere Pro CC 2015
    Posted by Adam Berch on January 18, 2018 at 5:26 pm
    I am working in Premiere Pro CC 2015 on an Imac. I have clips from a Sony Camera that I need to ingest into Premiere.
    How can I do this? I want to be able to pick and choose the clips I import before actually importing them.
    Thanks in advance.
    Adam Berch replied 8 years, 8 months ago 2 Members · 2 Replies
  • Eric Merklein
    January 18, 2018 at 11:29 pm
    Hello Adam.
    I use Sony cameras and importing is very easy.
    After transferring all of your clips to your IMac you can either pre-select by viewing clips using VLC, and importing after that, or import everything and blow it off after viewing.
    You can also pre-select by viewing from the media card from your camera first using VLC.
    E
  • Adam Berch
    January 19, 2018 at 12:59 am
    HI Thanks.
    OK When I play the clips through VLC, without Premiere open the clips play fine. When I open Premiere and try to import the clips, it goes to the Beach Ball and doesn’t do anything else. I always have to Force Quit Premiere.
    How can I stop this from happening? All I want to do is select all of the clips, import them into Premiere and start working.
    Do I need to download a Codec or something? If so, which one and where do I get it?
    Thanks in advance
