import scale problem
Sometimes when i import a file from illustrator into ae everything looks nice, but if you look in the scale properties of that layer it wont be 100%-100%.it could be 234%-531% for example. even if that happens my design will look ok.but when I try to rotate it(i also use duik tools) if those two numbers are not equal , i will get a deformed result.the design will be skewed.
does anyone know what that is happening?
ty
