Activity Forums Apple Final Cut Pro Legacy Import Problems
  • Import Problems
    Posted by Barrymac on September 22, 2006 at 3:52 pm
    I have been having a problem importing footage into FCP. It starts out OK but then it stops and says it is searching for a time code break, but there is no time code break. I have tried the work around of just importing an entire tape as a batch and capture now. Any idea as to what is going on?
    Jerry Hofmann replied 20 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 22, 2006 at 7:21 pm
    Possibly a weak timecode signal, or dirty heads on the playback machine.. a clone might help, or log just what you need and try capturing that. Is it every tape or just one?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
