Activity Forums Adobe Premiere Pro Import problems
  • Import problems
    Posted by Paulo Mateus on August 22, 2005 at 9:25 am
    I tried to import a quick time mov, made with Avid Express Pro 5 HD, to Adobe Premiere Pro 1.5, but that file plays with serious problems, plays a few frames per second and with some “noise” on it. I did many mov files from that project, with many different codecs (Sorenson 3, MPEG4, DV Pal, etc
    Paulo Mateus replied 21 years, 1 month ago 3 Members · 4 Replies
  • Mike Velte
    August 22, 2005 at 12:03 pm
    If your editing mode in Pro is DV, any video format on the timeline (other than DV) will not play smoothly without rendering preview files (Enter).
  • Paulo Mateus
    August 22, 2005 at 1:40 pm
    Yes, I know, but even after the rendering this image is slowly.
  • John Baum
    August 22, 2005 at 5:19 pm
    I’ve had this same problem and it seems to be related to Premiere and quicktime. I was trying to get a file from our avid system and tried many types of quicktime files and all played badly even though they played fine in the QT player.
    I looked at the properties of the clips that weren’t playing to see if I could find any clues and noticed that the FPS was 3! Even files rendered from After Effects on the same machine as Premiere showed this behaviour.
    The only work around I have found is to use AVIs instead.
  • Paulo Mateus
    August 22, 2005 at 7:14 pm
    Ok thanks
