Import Problem
Hi there,
I work on a Mac with the OSX 10.9.1 and my After Effects CS6 version is 11.0.3.6I have the following problem:
I have a relatively large project with lots of Adobe Illustrator drawings. I have been working with this project for a while now and this morning it started playing up.
Whenever I import a new Illustrator file I can drag and drop this element into a composition but it jumps to the topmost layer and I can’t drag and drop it further down. Once I have put the layer into the composition I can’t do anything to that layer or any other objects out of the Project window. When I try to drag and drop any object from the project window into a composition now I can’t do it, I don’t even get the outline box of the object when I drag it somewhere.I have trashed the preferences, restarted AE and the computer but the problem remains. I tried importing the project into a new project but the problem stays the same… I have tried it with many different objects so the Illustrator files aren’t currupt.
Has anyone ever has a problem like this before? Is it maybe that after Effects can only work with a specific amount of objects?
Any advice would be very appreciated.
Cheers,
Steffen.
