Activity Forums Sony Cameras Import problem – “insufficient disk space”
  • Import problem – “insufficient disk space”
    Posted by Sverker Hahn on March 13, 2008 at 2:17 pm
    When I try to import clips to FCP with XDCAM Transfer 2.1.0 I have gotten the message “There is insufficient disk space to import the selected clips” a few times.
    But now I get it every time I try to import my clips.
    How come?
    My scratch disk setting in FCP is a FW disk with 600 GB free.
    Sverker Hahn, Stockholm
    Slower is better!
    Sony EX1
    Canon XH A1
    iMac Intel
    Final Cut Studio 2
    Tony Tang replied 18 years, 3 months ago 3 Members · 3 Replies
  • Sverker Hahn
    March 13, 2008 at 2:35 pm
    Found the setting, which is in XDTranfer preferences …
    Slower is better!
    Sony EX1
    Canon XH A1
    iMac Intel
    Final Cut Studio 2
  • Colin Richards
    April 10, 2008 at 1:47 am
    Hi Sverker,
    I was just wondering how you resolved this problem. I’m encountering the same problem. I have a short term fix by importing long files into shorter clips but I’m interested in a better resolution.
    When you have a minute, let me know.
    Cheers,
    Colin
  • Tony Tang
    May 17, 2008 at 9:53 pm
    I encountered the same error message. I did not find any setting in the Preferences window that fixed the problem.
    Instead, I had to manually set the in/out points to the beginning/end of the clip and then Import. It worked after manually setting the in/out points.
    This happened on a clip that spanned two cards where the first half on the first card gave this error message.
    Tony
