Activity Forums Adobe Premiere Pro Import Powerpoint presentation to prem pro
  • Import Powerpoint presentation to prem pro
    Posted by Anton Glass on April 28, 2005 at 7:56 am
    Hi
    I’ve received a 5 page powerpoint presentation via email that needs to be added to a promo video I have shot and then cut on Prem Pro. I’ve tried importing it to the project but to no avail. I know it shouldn’t be that simple but I can’t figure out the conversion/format. How do I save the Power point file in a format that will be accepted by PremPro? If you have the answer please respond as simplistically as possible. I can shoot and cut in one format with confidence but when I have to start importing other stuff my head begins to melt.
    Many thanks in advance
    This is This
    Rob Posner replied 13 years, 1 month ago 6 Members · 6 Replies
  • Mike Velte
    April 28, 2005 at 11:25 am
    In PP, File>Save as…
    Change the “File of type” to Jpeg
    Use the Jpegs is Pro
    Sorry, you will loose all animation.
  • Brian Deviteri
    April 29, 2005 at 4:20 am
    Best way to save all the animation is to play the PPT through a VGA Scan Converter and record that to a DV deck… I do a lot of event coverage and use an Extron VSC 150 to DV or DVCPRO tape. Very simple to do actually, the Scan Converter hooks up like a VGA monitor and has a loop through as well.
  • Redgum
    April 29, 2005 at 2:46 pm
    I use a little program called CamStudio from http://www.atomixbuttons.com/vsc that screen captures at full resolution direct to an AVI file. I would do 2 or 3 PPT conversions each week and many have been to air. Makes my scan converter (about $3k’s worth) look cheap. Beauty is if you have a high resolution LCD wide screen 16:9 it will capture that format direct. It used to be freeware.
  • Dvlisarrr
    May 2, 2005 at 7:28 pm
    This link forwarded to Macromedia Breeze…
  • Dvlisarrr
    May 2, 2005 at 7:34 pm
    Sorry, meant to say that it auto-forwards to Macromedia CAPTIVATE (formerly called RoboDemo)
  • Rob Posner
    July 9, 2013 at 7:10 pm
    I just needed to do this myself for a project and couldn’t find the easy answer, so here is what I figured out.
    Open your power point file up, I use Power Point 2010 for windows.
    Click file, Save and Send, Create video.
    You can choose the size, how much time to spend on each slide, and where to save it. Then export it and import it into Premiere Pro CC or any other editing program that excepts WMV video files. Now all of your slides are there with the animations automatically enhancing. Cut it up like you would normally with any video.
    ENJOY!
    – Rob
    Rob Posner
    CEO/Executive Producer
    ProInnovation
    Video | Audio | Web
    (973) 842-8705
    482 Notch Rd. 1st Floor, Suite #1
    Woodland Park, NJ 07424
    https://ProinnovationProductions.com
