Activity Forums Apple Final Cut Pro Legacy Import photoshop pictures without changing the format/document size
  • Andrew Rendell
    February 14, 2011 at 4:07 pm
    The first thing I spotted is that in the first screen shot you’ve got a frame size for 720p but below it the pixel aspect ratio is PAL CCIR601 which is non-square pixels. That might not be the only issue, but it’s not going to help – it should be square.
  • Zane Barker
    February 14, 2011 at 5:11 pm
    Why are you using a “custom” setup in FCP? Use one of the photoshop presets so that everything is set up properly.
    **Hindsight is always 1080p**
