Activity Forums VEGAS Pro Import Part DVD
  • Import Part DVD
    Posted by James Reeve on July 16, 2011 at 3:56 am
    I see lots of help out there on how to import VOB files/DVD footage into Vegas (I use Vegas 10).
    However, this always imports the whole DVD, and this is a lot of time and disk space wasted.
    Is there are way of importing only a section of video from a DVD? For example, import from 23min to 34min (so a specified 11 minute segment, or chapter)?
    And, if the answer is “no, you have to import the lot”, is there a way I can dispose of the unwanted footage without affecting quality?
    Specifically, once I have imported the footage, I have an MPG file. A bit like photocopying a photocopy, you lose quality each time, and so too with rendering/converting video files (I gather). If I open the MPG in Vegas as its own project, cut off the top and tail to leave just my desired 11 minute segment, and then save it again as an MPG, will that second MPG have lost quality compared to the original?
    Thanks…
    John Rofrano replied 15 years, 2 months ago 5 Members · 4 Replies
  • Stephen Mann
    July 16, 2011 at 5:23 am
    You’re worrying about a few Gb of disk space when terabyte drives are around $60 today?
    If you *must* trim, then you can render a region to a new AVI file then edit that file.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Ted Snow
    July 16, 2011 at 8:17 am
    You could just hook a digital camcorder to the audio/video out of a DVD player and capture the segment you want through the firewire out of the camera. That way you have an AVI to work with that is only the length you want.
    ASUS P8P67 Deluxe MB
    EVGA GeForce GTX 560 Ti 1 GB DDR 5
    Intel i7 2600k 3.4 Ghz
    Corsair HX750 power supply
    Two Seagate Barracuda 500g SATA III drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Canopus ACEDVio card
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
  • Danny Hays
    July 16, 2011 at 5:15 pm
    You can just copy the one VOB file that has the section you want. Use Windows Explorer. Then change the extention from vob to mpg.
  • John Rofrano
    July 16, 2011 at 9:34 pm
    [James Reeve] “And, if the answer is “no, you have to import the lot”, is there a way I can dispose of the unwanted footage without affecting quality?”
    Get Womble MPEG VCR. It will allow you to open a VOB file, mark the IN and OUT point and click Save and it will copy the contents to a new MPG file with no re-rendering. You will have your original quality intact in the new file.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
