Activity Forums Panasonic Cameras Import P2 footage.. clip idle??
  • Import P2 footage.. clip idle??
    Posted by Arthur Luhn on April 11, 2007 at 8:14 pm
    Just tried to import a P2 clip through the panasonic aj-pcd20 15 second clip- I got a warning ! and a notification that the clip was queued but idle. What goes?
    Is this related to sequence? A mismatch?
    FCP 5.1.4
    OS X 10.4.8
    G5 2.66 GhHz Dual-core Intel Xeon
    Panasonic AJ-PCD20
    HVX-200
    1 TB Lacie
    MBE v.2
    Arthur Luhn replied 19 years, 4 months ago 1 Member · 1 Reply
  • Arthur Luhn
    April 11, 2007 at 9:14 pm
    I recorded a 15 sec clip at 480 NTSC 30fps and seeing that there is no NTSC 30fps in the FCP easy setup, set up a DV-NTSC sequence. When I tried to import the clip from the P2 card, it said the clip was in queue, but idle.
    Is this related to maybe the incompatibility of the sequence I just set up and the format I recorded in?
    many thanks
    FCP 5.1.4
    OS X 10.4.8
    Panasonic AJ-PCD20
    HVX-200
    1 TB Lacie
    MBE v.2
