Activity Forums DaVinci Resolve Import or Export Power Grades?
  • Import or Export Power Grades?
    Posted by Josh Petok on March 12, 2011 at 9:02 pm
    I can’t find a way to import or export grades from the Power Grades tab. I’ve looked in the manual, but couldn’t find much. Bringing grades to and from other systems seems like it would be a pretty common thing. I’m probably missing something really basic. Thx.
    Josh Petok
    JoshPetok.com
    Josh Petok replied 15 years, 6 months ago 2 Members · 2 Replies
  • Christopher Tay
    March 13, 2011 at 3:50 am
    I’m not sure if this will work. You can try export the project in the Config page using the Export+ when you right click on the project name and then only select Stills in the options dialogue box.
    The only thing I’m not sure if this will include the Power Grades or just the Stills tab for that project.
    Perhaps you can create a new project, copy those grades from Power Grades tab to the Stills tab and then export it out. Import this project on another system and then copy to the Power Grades tab.
    -chrispy
  • Josh Petok
    March 14, 2011 at 2:37 am
    Worked great! Thanks.
    Josh Petok
    JoshPetok.com
