Activity Forums Apple Final Cut Pro Legacy Import MXFs into FCP?
  • Import MXFs into FCP?
    Posted by Antony Christie on May 28, 2009 at 8:48 am
    A friend bought an PMW-EX1 two months ago and still hasn’t been able to get the MXF clips successfully into his FCP. We’ve managed to get the MP4s out of the camera (converted to MXF) using ClipBrowser (incidentally, is v2.0.0.0 the newest version for Mac?); however, his FCP (v6.0.5 on a new iMac) will not allow import of the MXFs (shows them as ‘white’d out’ files).
    Should v6.0.5 import MXF files? Does he need an update? A plug-in? Or 3rd party software like Flip4Mac?
    We did use 3rd party freeware to convert the MXFs into MOVs which worked (as a video plus 2 audio tracks) but it is obviously a far from ideal workflow and probably we are losing most of the meta data that MXF holds (and possibly quality?)
    John Fishback replied 17 years, 3 months ago 2 Members · 1 Reply
  • John Fishback
    May 28, 2009 at 3:01 pm
    Here’s a thread from the FCP forum that might help. If you search for MXF and XDCAM you’ll find more info. https://forums.creativecow.net/thread/8/1037915#1037915
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
