Activity Forums Avid Media Composer Import MXF into avid
  • Import MXF into avid
    Posted by Lena Gregorian on May 17, 2018 at 1:25 pm
    Hello all,
    I need to work with MXF files with avid 2018
    I placed the MXF under Avid Media Files / 1/ … (where the media is)
    got an error “file is not AP-ATOM”
    fair enough the MXF must be OP1-A
    I drag the file into avid (Import): and get exception MPEG mapper segment
    I try link to AMA: it says “failed to convert display to disk order
    WHY SO HARD? WHY?
    Michael Phillips replied 8 years, 4 months ago 2 Members · 1 Reply
  • Michael Phillips
    May 17, 2018 at 4:18 pm
    You can’t import OP1a, you can only link to it via AMA. Or option-drag them into a bin should default to the MXF AMA plug-in. WOuld be a nice feature that if dragged for import that MC prompt for you try a link rather than fail.
    Michael
