Activity Forums Adobe After Effects import multiple files?
  • import multiple files?
    Posted by Bob Sabiston on June 4, 2010 at 3:32 pm
    I have a sequence of BMP images and I want to import them as a continuous piece of footage, at say 5 frames-per-second. I’ve tried the ‘Import Multiple Files’ option and checked BMP sequence and even ‘force alphabetical order’, but it will only bring in one file. This is in CS3.
    The problem is that the files are ordered with three extra 0’s on the end. So, like this:
    I would have thought that AE would still do it, since they are technically in numerical order, but it won’t. Anyone know how I can do this in an easy way? I used to have a program to rename all the files and remove the trailing 000’s, but I don’t have that anymore.
    Bob
    Bob Sabiston replied 16 years, 2 months ago 2 Members · 2 Replies
  • Erik Waluska
    June 5, 2010 at 6:30 pm
    A way around this would be to put them all into a folder and import the folder using the “import folder” button. Once you have them in the project they should sort correctly in the project panel in numeric order from top to bottom so select all of the images by clicking on the first one first and then shift clicking the last one (the order you select them in determines the order they will appear in the composition) and drag them to the “new composition” icon at the bottom of the project window and set it to:
    – single composition
    – still duration of 1
    – sequence layers
    – uncheck “overlap”
    This will give you a pre-comp that’s basically the same as an image sequence.
    -E
  • Bob Sabiston
    June 5, 2010 at 8:07 pm
    wow thanks! I would never known how to do that. I actually was able to fix the sequencing on the originating side of the export, so I don’t need it now but I am glad to know it.
    B
