Activity › Forums › Apple Final Cut Pro Legacy › import mp3 files
import mp3 files
Posted by Ann Lukacs on February 8, 2006 at 2:58 amHow can I import mp3 files? Do I need to convert them to AIFF files? How do I do that? Thanks.
Shane Ross replied 20 years, 7 months ago 3 Members · 2 Replies -
Debe
February 8, 2006 at 3:03 amIn iTunes preferences, go to the Advanced settings. There should be drop downs that let you export to 48K AIFF files. You can also use the export function of QuickTime Pro.
debe
Shane Ross
February 8, 2006 at 3:06 amjust to expand on that:
#5 Imported music from CD or iTunes
Shane’s Stock Answer #5:
To get music into FCP, it needs to be an AIFF file at 48khz, 16 bit stereo. So if you want a song from a CD, you go into the iTunes Preferences and set this up under the IMPORTING tab:
File > preferences > importing > import using – AIFF encoder > Setting – Custom
Sample Rate – 48.000 kHz
Sample size – 16 bit
Channels – StereoIf you have an mp3 that you want to use, then you can convert it thru iTunes as well.
If the piece of music you want to use is something you purchased thru iTunes, I’m afraid I can’t help you there. There are copywrite issues that prevent files from being converted into the format that FCP can recognize.
Shane Ross
Alokut Productions
http://www.lfhd.net
