Activity › Forums › Adobe After Effects › import markers from a CSV document
Posted by oliver turm on February 4, 2024 at 5:06 amHi all, I’m wondering whether it’s possible to Import markers into Adobe After Effects from a CSV document?
Many thanks
Brie Clayton replied 2 years, 7 months ago 4 Members · 5 Replies -
Hector Vera
February 5, 2024 at 8:59 pmThis video I found may be able to help you to search for what you are looking for: https://www.youtube.com/watch?v=n45_hGd4INY
Its a general idea on how to utilize .csv files in After effects using Imports. Hope it helps and good luck! 🙂
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Walter Soyka
February 6, 2024 at 4:05 amUnfortunately, I don’t think the video linked above will help. It’s about importing CSVs as data sources into Ae, but there’s no way to get them to markers there.
This is totally doable with scripting, though. In fact, a quick search turns up this tool:
http://www.dispersiondesign.com/products/ae_scripts/import_markers/I haven’t used it, so I can’t vouch for it, but it looks to be exactly what you need.
Import Markers - AE Scripts - Products - Dispersion
oliver turm
February 6, 2024 at 8:50 pmHi Walter, you’re right. I ended up purchasing the script and it does exactly what I was after. Thanks very much.
