Activity Forums Zaxwerks import layerd ai to seperate sets?!?
  • import layerd ai to seperate sets?!?
    Posted by Bender on July 20, 2005 at 4:38 pm
    hey
    i created a fan in illustrator and saved it as an layerd illustrator 8 file. when i’m importing the file into invigorator it’s just on one set. i tried several options of the dialog box but nothing really worked.
    so how can i import a layerd illustrator file into seperate sets!
    thanks
    florian
    Bender replied 21 years, 1 month ago 2 Members · 2 Replies
  • John Dickinson
    July 21, 2005 at 2:54 am
    You can’t import a layered file so that each layer is in a separate set. You have to allocate the objects to different sets once the file has been imported. You can do this by selecting the object and choosing a set from the Sets pop-up menu to the right of the Object pop-up menu.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Bender
    July 21, 2005 at 4:46 pm
    thanks alot!
