Activity Forums Adobe Premiere Pro Import Keyboard shortcuts into CC from CS6?
  • Import Keyboard shortcuts into CC from CS6?
    Posted by Mike Weber on June 21, 2013 at 7:42 pm
    Hello
    I am upgrading to Creative Cloud from CS6. In Premiere, I would like to load in the same custom keyboard shortcuts I was using in CS6. Does anyone know how to do this? I tried copying the .kys files into the equivalent place on my Mac. home >> Library >> Application Support >> Adobe >> Premiere Pro >> 7.0. But the custom Keyboard Layout Presets do not show up in Premiere CC Keyboard Shortcuts. I suppose I can make them again from scratch, but would like to avoid doing that.
    thanks much
    Mike
    Ace Knuckles replied 11 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • Peter Garaway
    June 21, 2013 at 7:56 pm
    Hi Mike,
    Do note that the path has changed for Premiere Pro CC.
    In order to access your Premiere Pro CS6 keyboard shortcuts in Premiere Pro CC do the following steps:
    Mac:
    Copy your .kys file from
    /Users/[username]/Library/Application Support/Adobe/Premiere Pro/6.0
    and paste to
    /Users/[username]/Documents/Adobe/Premiere Pro/7.0/Profile-[username]/Mac
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
    Peter Garaway
    Adobe
    Premiere Pro
  • Mike Weber
    June 21, 2013 at 8:14 pm
    That did the trick, thanks a lot. Do you know if there a tutorial online somewhere explaining how to use Multicam in Premiere CC? I used it all the time in CS6, but since there is no longer a multicam window, I’m a little bit unsure how it works.
  • Peter Garaway
    June 21, 2013 at 8:45 pm
    Sorry not aware of any tutorials yet. But its fairly simple to use if you were familiar with CS6.
    1. Select your clips in the Project panel
    2. Right-click> Choose ‘Create Multi-Camera Source Sequence
    3. Multi-Camera dialog window appears. Choose how you would like to sync and there’s a few new options in there.
    4. Create a new sequence from your Multi-Camera source sequence
    5. ‘New in CC’ You know access the Multi-Camera monitor from the Program Monitor. You do this by going to the Program Monitor panel menu> Select Multi-Camera
    That’s the gist of it. Let me know if you have any other questions.
    Peter Garaway
    Adobe
    Premiere Pro
  • Chris Borjis
    June 21, 2013 at 10:32 pm
  • Todd Kopriva
    June 22, 2013 at 5:38 pm
    I created an extremely simple tutorial on using the new audio synchronization feature in a multicam project:
    https://blogs.adobe.com/premierepro/2013/04/a-quick-walkthrough-of-editing-a-multi-camera-sequence-with-clips-synchronized-by-audio.html
    It’s intended for someone with little to no experience with Premiere Pro.
    After Effects team blog
  • Bill Glader
    August 5, 2013 at 6:10 pm
    Wow, I hope Adobe comes up with a more intuitive way to use settings across multiple systems!
    BG
  • Todd Kopriva
    August 5, 2013 at 6:32 pm
    If you want to share settings between multiple computers using the same version of the application, there is an easy way:
    Sync Settings
  • Michael Head
    August 25, 2013 at 9:52 pm
    Quick question – I understand synching between systems for CC, but I”m moving from CS6 to CC – how do I import my presets, settings, and customization (example: workspaces I’ve setup) from CS6 to CC? I can’t find an easy way to do that yet.
    Thank you!
  • Todd Kopriva
    August 26, 2013 at 4:26 pm
    That’s because it doesn’t exist.
    You should submit a feature request:
    https://www.adobe.com/go/wish
  • Ace Knuckles
    November 16, 2014 at 5:58 pm
    Hey Peter,
    Things didn’t work out so well for me on this end. I’m using a MacBook Pro, Mac OS X Version 10.7.5.
    You stated the path below:
    When I follow that path on my computer, there isn’t a “Premiere Pro” folder inside of the “Adobe” folder. I tried to create a new keyboard layout with a distinct name so that I may search for it much easier but no results populate.
    What could be the problem? Thank you!
