Activity Forums Adobe Premiere Pro Import issue with jpeg sequences that are nested in Folders
  • Import issue with jpeg sequences that are nested in Folders
    Posted by Felix Gorbach on October 18, 2013 at 6:27 pm
    Dear Premiere Gurus,
    I have a little workflow issue. Made a nice timelapse with the GoPro cam. It recorded a single frame every minute. Those frames are nested in a lot of different folders sorted by date.
    In Premiere, when there is no jpeg sequence, it`s very easy to import the root folder and every movie is in the right folder and it´s not an issue to strart roughcutting.
    But with imagesequences – as far as I know – every imagesequence has to be imported as jpeg sequence on its own. So the similar workflow is just not possible – as far as I know… When I imprort the root folder, every single frame is imported – and not the sequences….
    For 20 sequences thats just clickwork – but for hundrets of them (as in my project) I will spend a day to import every single sequence on it´s own…
    Maybe there is a solution for this?
    Thanks for your advice,
    Felix
    Chris Gunningham replied 12 years, 11 months ago 2 Members · 3 Replies
  • Chris Gunningham
    October 19, 2013 at 11:50 am
    Don’t think you can do it without clickwork in premiere. You could use After Effects to import multiple files using a script such as immigration https://aescripts.com/immigration/
    You could then import the ae comp(s) into premiere.
    Chris Gunningham
    Online/VFX Editor
    Any opinions expressed are solely my own.
  • Felix Gorbach
    October 20, 2013 at 4:51 pm
    Thanks Chris,
    It works with immigration, even in CS6 perfectly.
    Thanks to all the folks on Creative Cow – you are awsome
  • Chris Gunningham
    October 21, 2013 at 8:50 pm
    Glad to be of help, Thanks for taking time to report back.
    Chris Gunningham
    Online/VFX Editor
